March 22, 2015
    Qorvo innovation brought the first surface-mount technology (SMT) solutions to high-capacity optical networks. Our optical modulator drivers, transimpedence amplifiers (TIAs) and optical module building block components lead the industry for efficiency, surface-mount convenience and high performance. Qorvo products are used by manufacturers to produce a wide variety of high-performance TOSA (transmit optical sub assembly) and ROSA (receive optical sub assembly) solutions in CFP, CFP2, CFP4 and QSFP28 formats. Qorvo's advantages allow manufacturers to reduce electricity consumption, speed assembly, reduce part counts, and deliver better, more reliable products. Global telecom and datacom companies use Qorvo solutions for their 10, 40, 100, 200 and 400 Gb/s systems. Qorvo has the most extensive reliability testing of any optical semiconductor company, with tens of thousands of actual device hours under accelerated life test conditions. Qorvo devices serve long-haul, regional, metro and local access optical infrastructure as well as data center backplane interconnection communications.
