August 31, 2018
    NB-IoT and LTE-M: How They Fit into the Cellular IoT EcosystemThe Internet of Things (IoT) will massively expand the use of cellular communications beyond smartphones and tablets to an extraordinary range of applications and connected devices — including many products that haven’t yet been invented.
    Although many IoT applications only need short-range wireless connectivity, a significant number will require longer-range connections. Examples include utility meters, sensors that monitor farm fields, or telematics modules tracking trucks on cross-country routes.
    That’s where cellular IoT comes in, and specifically the two cellular IoT standards expected to dominate the market: NB‑IoT and LTE‑M. Let’s explore these two standards, their potential uses and some implementation options for device makers looking to add cellular connectivity.
    Why we need NB‑IoT and LTE‑M
    LTE‑M (Long Term Evolution for Machines) and NB‑IoT (narrowband Internet of Things) are standards created by 3GPP, the standards organization responsible for LTE and 5G. They let operators leverage existing cellular infrastructure to support very wide deployment of IoT devices. Because they operate in licensed spectrum, they’re secure, reliable and provide guaranteed quality of service.
    Both LTE‑M and NB‑IoT fall under the category of machine-to-machine (M2M) communication, also known as machine-type communications (MTC). They help enable applications such as smart cities, environmental monitoring, asset tracking and more.
    Of course, operators already use older 2G and 3G networks for some IoT applications, like fleet tracking. But LTE‑M and NB‑IoT are different because they’re specifically designed and optimized for IoT devices that communicate small amounts of data over long periods of time. So they’re simpler than other cellular standards, with much less overhead. This translates into:
    • Very low power consumption, allowing device battery life of up to 10 years. That’s why these networks are also sometimes called low power wide area networks (LPWANs).
    • Long range and very wide coverage — several times better than LTE.
    • Low-cost hardware, due to the reduced complexity and economies of scale.
    • Up to 100,000 or even more devices per base station, because each device has very low data-throughput requirements and because optimized software techniques let base stations communicate with very large numbers of IoT devices.
    NB‑IoT and LTE‑M are the natural successors to older cellular standards for existing applications, and they’ll also drive development of completely new applications. Imagine if local governments could determine when waste bins need emptying, identify free parking spaces and automatically monitor environmental and road conditions.
    The following figure shows some of the IoT use cases enabled by massive MTC and critical MTC applications. Massive MTC relies on LPWAN technologies, including NB‑IoT and LTE‑M, while critical MTC will require real-time communications with very low latency and high reliability.
    Use Cases and Requirements: IoT and Machine Type Communications (MTC)
    Differences between LTE‑M and NB‑IoT
    The following table compares the characteristics of LTE‑M and NB‑IoT. The biggest differences are bandwidth and voice support, but for practical purposes, the differences for IoT device developers are likely to be small. NB‑IoT may use slightly less power and the required hardware may be slightly less complex.
    Comparison of LTE-M and NB-IoT Capabilities
    The momentum behind cellular IoT
    Perhaps the biggest reason that NB‑IoT and LTE‑M are so important is their huge industry momentum. According to GSMA*, operators have launched 58 NB‑IoT and LTE‑M networks as of July 2018, establishing coverage in most major markets worldwide.
    China has standardized on NB‑IoT, creating a potentially massive market that is likely to help drive development of IoT solutions. In the U.S., some operators (including Verizon and AT&T) launched LTE‑M networks first, but NB‑IoT networks are also planned.
    In many cases, operators can implement cellular IoT networks simply through a software upgrade to their existing base stations. This means they can roll out broad coverage very quickly and at low cost.
    What matters to device makers?
    Over the next few years, we’re likely to see thousands of companies design new products to take advantage of the opportunities opened up by cellular IoT. Here are some key considerations for device makers:
    • It’s important to take into account the steps needed to gain the operator certifications required to connect to licensed networks. Leveraging the expertise of RF partners can help overcome this challenge.
    • There will be a strong incentive to support both NB‑IoT and LTE‑M networks, to maximize potential sales. Fortunately, dual-mode chipsets are appearing that allow device manufacturers to build a single product for global deployment.
    • Many IoT devices will be expected to work reliably in the field for up to 10 years without needing service. So cellular IoT components must be very reliable, and replacement parts must be available for a long time.
    Qorvo’s portfolio of cellular IoT options for device makers
    Qorvo applies its RF technologies and expertise to a broad range of cellular IoT solutions, including products for IoT connectivity in devices and base stations:
    We’ve helped many companies achieve operator certification, and we supply industries such as automotive, aerospace and defense with very high requirements for product reliability and longevity.
    Cellular IoT: Enabling billions of new connected devices
    NB‑IoT and LTE‑M are just getting started. Over the next few years, these low-power cellular networks will open the door to a wealth of new applications, connecting billions of devices that need long-range connectivity combined with extended battery life. For makers of IoT devices, ensuring that products support both standards will maximize the opportunities.
    For more information on Qorvo solutions for NB‑IoT and LTE‑M, check out our portfolio of IoT products.
    *Note: Accessed as of 8/31/2018.
    Joshua Fogle
    Joshua Fogle
    Marketing Manager, RF Solutions for Mobile
    After 7 years of active duty in the U.S. Navy, Josh joined Qorvo to help connect customers with the right RF solutions. He currently applies his RF expertise toward creating the next generation of integrated products for IoT and M2M mobile applications.
    • Applications
      Internet of Things
      Qorvo's innovative portfolio enables the smart home, smart energy and other IoT applications.
    • Applications
      Mobile Products
      Qorvo's core RF solutions help next-generation mobile devices enable global connectivity.
    • Applications
      Base Stations
      Qorvo provides base station manufacturers with a broad range of semiconductor and module technologies.
    • Innovation
      5G The Future of RF
      Qorvo is the standard setter – participating in standards bodies and partnering with wireless carriers – to define 5G RF for the future.
    Connect with a Qorvo Expert
