Brent’s Musings: Beamforming, SATCOM and the Curious Case of Captain Spork
Qorvo Blog TeamFebruary 2, 2026
If there’s one thing the SATCOM world has taught us lately, it’s that the sky is getting crowded. Not with clouds or birds or even UFOs (pending government confirmation), but with LEO satellites—thousands of fast-moving nodes zipping overhead, all eager to help you stream movies from mountaintops, steer autonomous tractors or run Zoom calls from 38,000 feet.
But none of that works unless your ground terminal can keep up. And that’s where beamforming becomes the unsung hero of the modern space race.
Beamforming is what allows an electronically steered antenna to lock onto a satellite traveling at 17,000 mph without breaking a sweat — or breaking your connection. It focuses energy precisely where your terminal needs it, filters out interference and hands off seamlessly from one satellite to the next. Basically, it’s SATCOM’s version of perfect situational awareness.
When it works, it’s beautiful. When it doesn’t? Well…let’s consult the Starship Enterprise.
Transporters, Phased Arrays and a Tale of Caution
Imagine a SATCOM ground terminal with perfect beamforming: every element synced, every phase aligned, every beam locked onto the right LEO bird. Your terminal tracks satellites faster than Kirk can order red alert. Life is good.
Now imagine the opposite — a phased array with phase errors, calibration drift, sloppy side lobes, significant performance drop at high scan angles and maybe a little thermal chaos sprinkled on top. Suddenly your beam points almost where it should.  Your phase is a bit out of phase.
Instead of beaming up Captain Kirk and Mr. Spock, you get a beamforming mash-up.  And the result?
Captain Spork — half logical, half impulsive, all confused about why his communicator keeps connecting to the wrong satellite.
Transporters are basically a SATCOM nightmare scenario: extremely high-stakes data transmission with catastrophic consequences for imperfect reconstruction. Beamforming is no different — although the fallout in our industry is thankfully limited to dropped links, not hybrid Starfleet officers.
Still, the analogy holds — If your phases aren’t aligned, neither is your outcome.
Beam me up, Scotty! Perfect beamforming gives you Captain Kirk and Mr. Spock. Misaligned phases give you a mash-up: Captain Spork. When your phases aren’t aligned, neither is your outcome—especially in SATCOM.
Why Beamforming Matters More Than Ever in LEO SATCOM
LEO constellations don’t sit politely in geostationary orbit like their older GEO cousins. They move. Fast. Your ground terminal must:
  • Acquire the right satellite
  • Track it as it streaks across the sky
  • Hand off gracefully to the next satellite (without a lot of additional hardware)
  • Avoid interference with adjacent satellites and terrestrial signals
All of this happens in real time, across a wide field of view, with strict regulatory constraints on where your beams can and cannot go. Miss by a few degrees, or even a few tenths, and suddenly your link budget looks like a transporter accident.
Electronic beamforming solves this by steering beams instantly, accurately and continuously. It keeps your ground terminal tethered to the right LEO node like a cosmic dance partner. And as constellations grow from hundreds of satellites to thousands (or tens of thousands), beamforming becomes the only scalable way to maintain reliable links without aiming a giant mechanical dish at the sky like it’s 1995.
A Lesson for SATCOM Engineers (and Starfleet)
Whether you build terminals for ships, aircraft, vehicles or backyard broadband, the message is the same:
Beamforming isn’t optional — it’s survival.
It ensures your signal doesn’t drift, your handoffs stay smooth and your constellation doesn’t accidentally create more Captain Sporks.
Because in SATCOM, just like on the Enterprise, you want the right signal to show up in the right place as the right version of itself.
And if you do encounter Captain Spork, please alert Starfleet…or at least the nearest spectrum management authority.
This article first appeared in Brent's Musings in Microwave Journal
