How Qorvo UWB Technology Helps Hospitals Move Faster and Smarter
Blog PostNovember 17, 2026
Before the day fully begins, Hong Kong’s largest hospitals are already in motion. Staff prepare for incoming patients, equipment moves between departments and the pace builds quickly. Once it starts, it rarely slows.
For care teams, the real strain often comes from what should be simple: where to find a needed device, or a wheelchair has been moved or a monitor is in use somewhere else. Time is lost searching, and those delays ripple into patient care and staff workload.
In environments like these, what seems like the smallest inefficiencies can have an outsized impact.
The Challenge: When Visibility Falls Short
Large urban hospitals operate as tightly connected systems. Patients can struggle to find their way. Nurses can spend valuable time locating tools. Administrators may not have a clear picture of how resources are being used in real time.
Without clear visibility, routine tasks become harder to manage.  As one operations manager put it, “Hospitals are dynamic environments where accuracy and timing matter. We needed a solution that could make navigation effortless and improve staff coordination without disrupting workflows.”
The issue was not effort. It was the absence of precise, real-time awareness.
Solution: Enabling Precision with UWB
To address this, a central district hospital in Hong Kong worked with Minew to introduce a real-time navigation and asset tracking system built on Qorvo’s Ultra-Wideband technology.
Take a Deeper Dive
  • Peruse our other customer success stories
  • Explore our UWB design partners
  • Read the technical article: The Future of Positioning: Exploring UWB and Bluetooth Channel Sounding
WR462_2025_05_12_UWB_Access_Control_90_Percent_PG1.svg
Figure 1: UWB Time-of-flight for measuring range between two devices.
Qorvo’s UWB capability is fundamental to the system’s performance. By calculating the exact flight time of signals, it provides highly accurate positioning, even in environments filled with interference, reflective materials, and structural complexity. That precision allows location data to remain consistent and dependable throughout the facility.
Minew designed the system around these capabilities, tailoring the deployment to the hospital’s layout. The result is a network that supports everyday movement within the building, helping patients reach their destinations and enabling staff to quickly locate critical equipment.
“Qorvo’s UWB gives our beacons the stability and precision that complex hospital environments demand,” said Tim Li, product manager at Minew. “It transforms location data into actionable insight.”
A Network Built for the Environment
To establish full coverage, Minew installed two types of UWB beacons across the hospital. Smaller, energy-efficient units support navigation in shared spaces such as hallways and waiting areas. Longer-range devices extend coverage for asset tracking and monitoring in key zones.
Qorvo’s UWB technology underpins both, allowing the system to maintain accuracy across different parts of the hospital without interruption.
Because the beacons operate for years on a single battery, installation is straightforward and ongoing maintenance is minimal. Patients can navigate through a mobile app with clear direction. Staff can identify the location of equipment almost immediately. Administrators gain a better understanding of how space and resources are being used.
The Results: Measurable Improvements
The impact became clear within months. Patient wait times decreased from about 35 minutes to 28. The time required to locate equipment dropped from several minutes to less than one. Staff satisfaction increased from seventy percent to ninety-one.
These results reflect meaningful changes in day-to-day operations. Patients experience fewer delays and less confusion. Staff regain time that can be redirected toward care. Workflows become more predictable and less interrupted.
The system also reduces infrastructure demands. Its low-power design removes the need for Ethernet connections or external power, keeping installation and maintenance requirements low.
Why Qorvo’s UWB Matters
The effectiveness of the system depends on the performance of Qorvo’s UWB technology. Its precise timing enables centimeter-level positioning, which is critical in environments where accuracy directly affects outcomes. Secure ranging helps protect sensitive location data. Energy efficiency supports long-lasting devices. Strong resistance to interference ensures reliable operation in busy hospital settings.
Together, these capabilities allow Minew’s solution to deliver consistent, real-time visibility.
Looking Ahead
What this hospital has implemented reflects a larger movement toward smarter, more responsive buildings. As expectations for efficiency and experience continue to rise, real-time location awareness is becoming essential.
In healthcare settings, that shift is especially important. Clear navigation and reliable coordination can ease stress for patients and give staff more control over their environment.
Minew’s deployment highlights how real-time visibility can improve hospital operations, with Qorvo’s UWB technology providing the accuracy that makes those improvements possible.
About Minew
Founded in 2007, Minew Technologies develops IoT hardware across Bluetooth, UWB, Cellular, and LoRaWAN technologies. Its portfolio includes beacons, sensors, and gateways designed to support real-time visibility and connectivity across healthcare, logistics and industrial environments.
Take a Deeper Dive
Looking Ahead
About Minew
