PAC EVK Quick Start: 1 - Hardware Setup
April 20, 2026
Get up and running with the PAC FOC platform using the EVK. This chapter walks through the full setup process, starting with hardware connections and moving through tools, firmware and project configuration.
You’ll learn how to build and program the firmware, then use the GUI to bring your motor under control. By the end, your system is running and ready for tuning.
Start with the first video, then move to Part 2 to install the firmware and tools.
Watch More
PAC EVK Quick Start: 2 - Firmware & Tools
Install the required tools and access PAC firmware resources. You’ll see where to find everything you need to prepare your development environment.
PAC EVK Quick Start: 3 - Project Setup
Open the FOC project in Keil and install device support. This step gets your project ready for configuration and development.
PAC EVK Quick Start: 4 - Build & Flash
Configure key settings, build the firmware and program the target. By the end, your system is ready for initial operation.
PAC EVK Quick Start: 5 - GUI Overview
Use the PAC FOC GUI to monitor and control motors. Learn the layout, key controls and how to interact with your system during bring-up.
April 20, 2026
Watch More
