PAC EVK Quick Start: 3 - Project Setup
April 18, 2026
Open the FOC project in Keil and install device support. This step gets your project ready for configuration and development.
At the conclusion of this video, you will be ready for Part 4 to configure, build and flash the FOC firmware.
Watch More
PAC EVK Quick Start: 1 - Hardware Setup
Get up and running with the PAC FOC platform using the EVK. This chapter walks through the full setup process, starting with hardware connections and moving through tools, firmware and project configuration.
PAC EVK Quick Start: 2 - Firmware & Tools
Install the required tools and access PAC firmware resources. You’ll see where to find everything you need to prepare your development environment.
PAC EVK Quick Start: 4 - Build & Flash
Configure key settings, build the firmware and program the target. By the end, your system is ready for initial operation.
PAC EVK Quick Start: 5 - GUI Overview
Use the PAC FOC GUI to monitor and control motors. Learn the layout, key controls and how to interact with your system during bring-up.
April 18, 2026
Watch More
