Designing Efficient Satellite Links: A Review of the Link Budget Analysis
September 8, 2025
In an RF communication system, the path a signal takes between the transmitter to the receiver is called a communication link. When designing such systems, evaluating the signal strength, noise and losses along this link is known as performing a link budget analysis.
In telecommunications system design, one of the most critical steps is calculating the link budget, a theoretical assessment of the performance of a communication link from end to end. Engineers perform this through link analysis, a process that quantifies the expected gains and losses in the system under specified conditions. This analysis helps predict how effectively data can be communicated between a transmitter and receiver, considering all relevant system parameters.
The performance components in this analysis include transmit power, antenna gains, path loss, receiver sensitivity and additional losses such as those due to atmospheric absorption, multipath fading or system imperfections. See Figure 1. By organizing these values into a structured calculation, engineers can assess whether the received signal power is sufficient to meet the required quality of service and support the desired waveforms in the communication channel. Each component plays a critical role in shaping the final link budget, and understanding their contributions is essential for designing reliable and efficient communication systems.
WR562_pg2.svg
Figure 1: Satellite communications link budget and factors influencing it.
Optimizing the RF link budget of satellite systems is pivotal for ensuring reliable communications. Advanced design techniques are necessary to enhance and maintain signal quality, improve spectrum efficiency and robust connectivity. This article explores the link budget associated with satellite communication networks and the aspects of calculating it, along with some techniques for addressing its challenges during design. One type of calculation is the Friis Transmission Formula, as shown below, which is a fundamental equation used in telecommunications that relates the power received by an antenna to the power transmitted by another antenna, considering the distance and antenna characteristics. It is used primarily to estimate the received signal in wireless communication systems under idealized free-space conditions.
WR562_pg3.svg
Key Parameters in Satellite Link Budget Communications
The Antenna Gain-to-Noise Temperature Ratio (G/T) is another key figure of merit for receiver systems and plays a critical role in satellite communication networks. Antenna gain reflects the system's ability to focus and amplify incoming RF signals, while antenna noise temperature measures the total noise power captured by the antenna from various sources, including sky temperature, LNA noise temperature and feed loss temperature. A thorough understanding of the G/T ratio is essential for the design, analysis and optimization of satellite communication systems and their associated link budgets.
On the receiver side of a satellite communications network, the G/T ratio compares the receiving antenna’s gain to the system’s overall noise temperature. It quantifies the antenna’s effectiveness in capturing desired signals relative to the background noise. A higher G/T ratio indicates better performance in receiving weak signals while minimizing the impact of system noise. This metric allows engineers to optimize key parameters, such as antenna size, receiver sensitivity and noise figure, to achieve an optimal balance between signal reception and noise suppression. See Figure 2.
The G/T of an antenna is calculated by dividing the antenna’s receive gain by its equivalent system noise temperature, as shown in the equation below. Antenna gain quantifies the ability to receive and direct RF signals effectively, while the equivalent noise temperature represents the total noise contribution from the antenna system. The resulting G/T value is typically expressed in decibels per Kelvin (dB/K), providing a standardized measure of antenna performance.
Antenna G/T = Antenna Gain (dBi) – [10 log10(System Noise)]
The G/T ratio plays a vital role in the link budget of satellite communication systems. During system design, engineers rely on the G/T ratio to perform accurate link budget analyses.
WR562_pg4.svg
Figure 2: Satellite link showing EIRP and G/T.
Effective Isotropic Radiated Power (EIRP) is another critical metric in satellite communication link budgets. It combines transmitter output power with antenna gain and indicates how effectively a system can send signals. Higher EIRP improves signal-to-noise ratio (SNR) at the receiver, enabling longer transmission distances and greater resilience to interference. Maximizing EIRP enhances both uplink and downlink performance by strengthening signal reliability and reducing required link margins. Modern improvements in EIRP allow satellite systems to support more users per cell site, expanding coverage, increasing link capacity and delivering higher data rates with better quality of service (QoS) for end users.
EIRP (Transmit) = Pt – Loss + Gt
(where, Pt = transmit power and Gt = transmit Gain)
The distance between the transmitter and receiver significantly affects the SNR due to path loss. SNR quantifies the relative strength of the desired signal to the background noise level. A higher SNR indicates better signal quality and reception. As the range increases, the signal strength weakens, reducing the SNR and impacting communication quality, especially at mmWave frequencies, where attenuation is more severe. Maintaining a high SNR is essential for reliable satellite communication, as it ensures better signal quality, higher data rates and lower bit error rates (BERs).
Moreover, a high SNR enables the system to utilize more complex modulation schemes, allowing for faster data transmission. Conversely, a lower SNR forces the system to use simpler modulation schemes, leading to slower data rates to ensure signal integrity. A strong SNR allows for faster, higher capacity data transmission, while a low SNR leads to degraded performance, increased latency and reduced throughput due to packet loss and retransmissions. Effective system design aims to minimize these losses and maintain sufficient SNR for optimal performance.
Calculating the SNR link budget is essential for evaluating satellite communication system performance. Since factors like channel bandwidth and free-space path loss (FSPL) are typically fixed, designers must carefully balance transmit EIRP from the satellite with the ground terminal’s G/T ratio to optimize performance. Improving G/T involves selecting high-gain receive antennas, minimizing system noise through careful component design and applying signal processing techniques to boost SNR. However, achieving a high G/T ratio often requires trade-offs—larger antennas, increased complexity, higher power consumption or greater cost. Engineers must balance these factors to meet system requirements while staying within practical limits.
SNR affects how well data can be transmitted in a communication system. As shown in Figure X below, different modulation methods need a certain minimum SNR to work properly. For instance, in a Ku-band downlink with an SNR of 3.15, a suitable modulation is DPSK ¼, which offers a spectral efficiency of 0.75 bps/Hz and a maximum data rate of 3.75 Mbps assuming a channel BW of 5 MHz.
In general, a low SNR means a lower data rate, while a high SNR allows for a higher data rate. Systems can use adaptive modulation to switch based on SNR levels, but doing so requires more advanced digital processing.
SNRdownlink (dB) = EIRPsatellite (dBWi) – Channel BW (dBHz) – FSPL (dB) – AFPL (dB) + G/Tterminal (dB/K) – k (dBJ/K)
(where, SNR = signal to noise ratio, EIRP = Effective Isotropic Radiated Power, FSPL = free space path loss, AFPL = atmospheric path loss, G/T = antenna gain-to-noise temperature ratio and k = Boltzmann’s constant) – produces the overall SNR in the channel BW.
WR562_pg5.svg
Figure 3: SNR calculation of a Ku band geostationary downlink system.
A small bit to explain modulation as shown in the above figure. Every satellite link is designed with a specific MODCOD (modulation and coding) scheme. Modulation encodes digital data by shifting the phase of a carrier signal. Phase Shift Keying (PSK) is a common method: for example, BPSK uses two phases (180° apart), while QPSK uses four, doubling the data rate in the same bandwidth but requiring more power. To avoid needing an absolute phase reference, Differential PSK (DPSK) shifts phase relative to the previous bit.
Satellites typically use APSK, one of the main reasons for using APSK in satellite applications is that it is robust with regard to various amplitude effects and relaxes the linearity requirements of transmit power amplifiers. Non-linearities such as PA compression may change the relative distances between different amplitude rings, but all the points on a given amplitude ring will be equally affected, which minimizes the impact of this non-linearity. Therefore, APSK allows the distances between rings to be pre-distorted so that the rings are the correct distance apart after non-linear amplification. APSK provides further flexibility, so that the number of rings and distance between the rings can also be chosen or adjusted to balance distortion versus peak-to-average power ratio.
WR562_pg6.svg
Figure 4: 32APSK Constellation.
As shown in the figure below, as a satellite moves relative to a receiver, the frequency of its transmitted signal experiences Doppler shifts. These variations can cause synchronization challenges that impact communication reliability. To address this, the system must continuously monitor and compensate for the frequency shifts. Advanced algorithms play a critical role in this process, enabling the receiver to adjust dynamically and maintain stable, high-quality signal reception.
WR562pg72.svg
Figure 5: Key environmental metrics that impact system performance.
System losses are inherent to all satellite communication systems and can originate from various components within and between the ground station and the satellite. Signal degradation may occur due to imperfections in hardware such as antennas, power amplifiers, RF filters and transceiver signal processing units. At higher frequency bands—such as Ka and Q/V—the impact of atmospheric attenuation and free-space path loss becomes more significant, further exacerbating signal degradation and requiring careful compensation in system design.
Optimizing the RF Link Budget
Engineers use several ways to address these challenges, such as using phased antenna arrays and beamforming, adaptive power control to ensure SNR is optimized by making the key adjustments in transmit power based on real-time link conditions and machine learning approaches, as well as adaptive coding and modulation techniques to enhance the communication performance.
Adaptive Coding and Modulation (ACM) helps improve satellite communication by changing how data is sent based on the quality of the signal. When the signal is strong, the system uses faster methods to send more data. When the signal is weak, it switches to more reliable methods to avoid errors. This makes the connection more efficient and dependable, especially for low Earth orbit (LEO) satellites that move quickly and pass over different areas. ACM adjusts automatically in real time to keep the signal steady and prevent interruptions.
Machine learning (ML) is becoming another powerful tool for engineers optimizing link budgets in satellite communication systems. By providing predictive and adaptive capabilities, ML helps manage resources more efficiently in dynamic environments. Techniques like reinforcement learning enable real-time decisions for power control, handovers and bandwidth allocation, while supervised learning predicts signal degradation and path loss for proactive adjustments. For example, ML algorithms can boost transmit power during high-demand periods or ensure seamless handovers between satellites. This data-driven approach is transforming satellite network design, improving performance and reliability under varying conditions.
Conclusion
In conclusion, optimizing the RF link budget is essential for designing reliable and efficient satellite communication systems. By carefully analyzing parameters such as EIRP, antenna G/T and SNR, engineers can predict and enhance link performance across diverse operational conditions. Advanced techniques like adaptive coding and modulation, real-time power control and machine learning-driven optimization are reshaping the way satellite networks are designed—enabling higher data rates, improved spectral efficiency and robust connectivity in increasingly dynamic and demanding environments.
Additionally, you can find more information on this subject by visiting our Qorvo Design Hub for a rich assortment of videos, technical articles, white papers, tools and more. For support, please reach out to Technical Support.
About the Authors
Our authors bring a wealth of technical expertise in developing and optimizing wireless solutions. With a deep understanding of customer needs and industry trends, they collaborate closely with our design teams to drive innovation and deliver cutting-edge solutions that support industry-leading products.
Thank you to our main contributors to this article: James Cheng (Sr. Product Line Manager), David Corman (Chief Systems Architect) and David Schnaufer (Corporate Technical Marketing Manager) for their contributions to this blog post, ensuring our readers stay informed with expert knowledge and industry trends.
September 8, 2025
WR562_pg2.svg
WR562_pg3.svg
WR562_pg4.svg
WR562_pg5.svg
WR562_pg6.svg
WR562pg72.svg
Conclusion
About the Authors
